Oil rod
15 years 10 months before #10792 by manual-mecanica
oil rod posted by manual-mecanica
Hello colleagues I am new on these issues but I see that they respond to consultations and I will look at if they can solve me or give an idea to my problem.
I have a Land Rover Freelander of 99 and the other day when I look at the oil I broke the rod of looking at the oil I could take it out but at the tip I had a black plastic thing and now it is not when it puts it again does not let me introduce it until the end. What can I do?
Some friends said that when changing the oil that disassemble the carter lid and there could be to solve the problem but the carter would not carry a joint and you will have to change, I wait for your clarifications if you can thank you in advance and I like this I will be here for a long time asking and clarifying thanks thanks
15 years 10 months before #10862 by manual-mecanica
Manual-Mecanica Response on the Re: Oil Rod
Ola friend, the black thing that you say that is not, was it from Plastiko? Does it belong to the metal barilla case?. If so, esqe aora simply the metal Barilla lowers the bottom and the cater. 1 greeting
15 years 10 months before #10867 by manual-mecanica
If it was plastic, but before the rod entered everything and now it stays half enter it remains on half it before it becomes as it was before
15 years 10 months before #10876 by manual-mecanica
Take out the metal and clean it must be clogged
15 years 10 months before #10882 by manual-mecanica
And how do you not have to disassemble the carter? You see that I am new in these things
