Chrysler Neon 2000
15 years 10 months before #10747 by manual-mecanica
Chrysler Neon 2000 published by Manual-Mecanica
The engine when it is on ranges between 700-800 rpm, when normal is 1000 rpm, as I do to increase rpm to 1000
15 years 10 months before #10748 by manual-mecanica
Manual-Mecanica Answer on the Re: Chrysler Neon 2000
As the first measure clean the engine that regulates the idle and its seat. It is located in the body of Acceleration.
15 years 10 months before #10857 by manual-mecanica
From the outset, the idle of this engine is 800 rpm, this speed is controlled by the motor computer (PCM). It is possible to raise it to what you want, but it will bring you consequences, as an increase in fuel consumption.
As he said to you, you have to wash the Valvila IAC and acceleration body, I also recommend that you clean the injectors.
If you do not conform after cleaning, let's tell us to tell you the trick ...: Cheer: [IMG/]
15 years 10 months before #10881 by manual-mecanica
Indeed 1000 revolutions is a lot for the minimum march of any car. Could you know where you got the idea of ​​the thousand rpm?
15 years 10 months before #10887 by manual-mecanica
What happens Lord is that there is a trembling in the steering wheel, and a partner told me that he lacked engine acceleration, which should be in 1000 rpm, and when I accelerate it manually up to 1000 rpm the tremor disappears, so I ask for tips before taking an action, already clean the injectors and continue, I need to check the IAC and the acceleration body, thank you very much.
