Chrysler Neon 2000
16 years 3 weeks before #10747 by manual-mecanica
Chrysler neon 2000 Published by manual-mecanica
The engine when it is on ranges between 700-800 rpm, when normal is 1000 rpm, as I do to increase rpm to 1000
16 years 3 weeks before #10748 by manual-mecanica
Manual-mechanics' response on the topic Re: Chrysler Neon 2000
As a first step, clean the idle control motor and its seat. It's located in the throttle body.
16 years 1 week before #10857 by manual-mecanica
To begin with, this engine's idle speed is 800 rpm, controlled by the engine control unit (PCM). It's possible to increase it to your desired speed, but this will have consequences, such as increased fuel consumption.
As Jueja correctly mentioned, the IAC valve and throttle body need cleaning. I also recommend cleaning the injectors.
If you're still not convinced after cleaning, let us know so we can tell you the trick...: Cheer: [img/]
16 years 1 week before #10881 by manual-mecanica
Indeed, 1000 revolutions is a lot for the idle speed of any car. Could you tell me where you got the idea of ​​1000 rpm?
16 years 1 week before #10887 by manual-mecanica
The problem, sir, is that there's a vibration in the steering wheel, and a friend told me the engine needs more acceleration, that it should be at 1000 rpm. When I manually accelerate it to 1000 rpm, the vibration disappears. That's why I'm asking for advice before taking any action. I've already cleaned the injectors, and it's still happening. I still need to check the IAC valve and the throttle body. Thank you very much, brother.
