VW Golf IV Retrvers Problem
15 years 11 months before #10698 by manual-mecanica
VW Golf IV Retisers Published by Manual-Mecanica
Well, the problem is as follows:
the electric mirrors that are controlled from the inside, moving a shovel next to the driver's door command, do not respond to the palanquita. This lever controls the movement inside the rearview mirror and right.
He has stopped working because one car the other day he gave me with his rearview mirror to mine (from the driver) and neither of them no longer works.
I have looked at the fuse but it seems good. Anyway, if someone can give me an idea of ​​where to search or do, I would do a favor. Thank you.:)
15 years 10 months before #10720 by manual-mecanica
Manual-Mecanica Response on the Re: Electric Problem Retistores VW Golf IV
The first thing to do is see if the palanquita comes run as you are called, if there is a current to see if you get current to the mirrors you have that first and let us know.
15 years 10 months before #10721 by manual-mecanica
ha and check the relays,
