Hyundai Atos Gls
16 years 3 weeks before #10681 by manual-mecanica
hyundai atos gls Published by manual-mecanica
Hi everyone, yesterday I changed the spark plug wires and noticed one of them had been loose for a while, but the car was running fine. Now that I've put new ones in, the car is losing power. Why is this? I'm so confused.
Thanks!
16 years 3 weeks before #10707 by manual-mecanica
Manual-mechanics' response on the topic Re: Hyundai Atos GLS
Hey friend. What year is your Atos? Where was the loose wire you found? Was it loose but connected to the spark plug? If so, it's very likely you'll have to change them. I also recommend checking and/or changing the air filter, and the fuel filter, which is located underneath near the left rear wheel. Cheers! B)
16 years 3 weeks before #10726 by manual-mecanica
Hey, check the firing order!
It could be that if it's a spark plug wire, it doesn't go on the spark plug where you put it. You better double-check that, okay?
: Laugh:
16 years 1 day before #10994 by manual-mecanica
If, as your buddy says, the firing order is 1-3-2, bye
15 years 11 months before #11017 by manual-mecanica
Check if you left any loose connector or if you let go without any connector the order should be 1-3-4-2 and check the spark plugs, greetings, I could be or rather check if you left any loose emptiness hose.-
