Problems with instrument board light
15 years 11 months before #10669 by manual-mecanica
I have a problem with my Hyundai Accent and it was that I was doing the change of the bulbs of the antinebline headlights and once that was over, I proceeded to turn on the car, and it was at this time that I realized that the light of the board did not turn on something that did not happen before since it worked perfectly, I would like it know if someone has happened to him this and within the experience of the people of the forum, which could be the cause of the forum. thank you....
15 years 11 months before #10674 by manual-mecanica
Manual-Mecanica response on the Re: Problems with instrument board light
You mean the light that indicates that the fog lights are on?, if only that, can the dashboard molten and nothing more, but it is very little the data you provide, I do not understand that light does not turn you to? Is it just one? Antinieblas work? Is there something that I don't mean?
15 years 11 months before #10678 by manual-mecanica
The problem arose after the change of antinebline headlights, the headlights are fine, which does not illuminate is the board, at the time of locks the lights should be illuminated the board and this does not happen.
