Mitsubishi Colt Glx 1.5 carburetor explorations
15 years 11 months before #10637 by manual-mecanica
I have a mitsubishi Colt GLX 1.5 Model 95, and the carburetor is exploiting already clean and follow the problem, spark plugs and cables were checked and continues, which can only be the tank with extra gasoline.
15 years 11 months before #10640 by manual-mecanica
Look there are barias things to check, first make sure that the set -up is correct, then check that the distributor's lid is not with cracks, you almost do not see with the naked eye, what you can do to project is to make a little oil on this lid and give start if this trisada is removed, if you already check cables and spark plug Platinum and Condenso Checalos in the same way, and finally a corburada and within this stretch that the pneumatic accelerator is good and that you have no problems with the servo brake.
