problem to light Chrysler Neon 2000
15 years 11 months before #10623 by manual-mecanica
problem for lighting Chrysler Neon 2000 published by Manual-Mecanica
The car was left without gasoline, I started it 2 times and nothing, then the tank was filled, and I was starting again and nothing, by the accordion I took gas and start but not manfuue, purge the flute and leave gas, ask how I can rule out that the gasoline pump is damaged, and how much voltage must have the gasoline pump and that gasoline pressure must remain in the flute of the flute
15 years 11 months before #10633 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem to light Chrysler Neon 2000
Friend look I recommend that before you continue doing purges or blood the bomb in Chrysler it usually happens that when not purging the pump they do not leave and do not leave, you must take it out, load it and put it, then with another battery you give direct current to the pump until it begins to throw a continuous and strong jet then you put the mangroves and give it when you go to run it and you will accelerate it and you will accelerate it.
15 years 10 months before #10727 by manual-mecanica
Hello friend, the same thing happened to me, a shadow, it happens is the glass of the gasoline pump, as well as I recommend it is sakar the pump check a battery a battery k works the pump yk dè from 30 to 45 pounds of pressure if it worked outside the pump should not xk fail inside.
So k when it rides it only kompruba k the pump glass is full for k begins to pull gasoline from the first moment k des arranke
: Ohmy:
