Opel Opel Opel Bpel B 2.5 TD
15 years 11 months before #10620 by manual-mecanica
Opel Opel Opel Bapelizer B 2.5 TD Published by Manual-Mecanica
The immobilizer light of my Opel Omega has been lit and I can't start it, my question is if there is any way to cancel it. (The red light of the command flashes) .urge Answer to use the car.
Thanks and greetings.
15 years 11 months before #10630 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Opel Imevalizer B 2.5 TD
Test disconnecting the battery the negative some treita seconds, Abesses is solved, it can be unlock with a scanner, and if they can be canceled for centro but it depends on the type of immobilizer.
15 years 11 months before #10636 by manual-mecanica
Try to start another key, sometimes the key is going.
15 years 11 months before #10638 by manual-mecanica
I have disconnected the battery and what happens now is that when giving command flashes the inner light of the car. thank you
15 years 11 months before #10639 by manual-mecanica
The keys do not work, just to open and close the car, to disconnect the immobilizer it has to be with the command, thanks
