I need urgent information. Thank you
15 years 11 months before #10577 by manual-mecanica
I need urgent information. Thank you published by Manual-Mecanica
Hello, how are you mechanical partners, I request your help to solve a problem that I have with a Pointer 1.8 LTS Mod.2005 vehicle without distributor. It turns out that I do not know if the crankshaft sensor's rally is synchronized well in the engine rear and separately has a variation in the engine revolutions and marks the short -to -dough camshaft sensor code, I need a diagram to be able to synchronize the rally of the crankshaft sensor. I will thank you for the information. If they need manuals I have enough and mechanical programs such as ONDEMAND5 or the 2008 Autodata.
15 years 11 months before #10605 by manual-mecanica
Manual-Mecanica Response on the Re: I need urgent information. Thank you
Mass cuts are current leaks in positive or negative cable, check with a cable put by you to see what happens.
