ELECTRICA FAILURE LEVELS GLASSES D MAX
16 years 1 month before #10565 by manual-mecanica
Hi everyone, I'm hoping I can find a solution. I have a D-Max and sometimes the electric window controls and other functions on the driver's side door stop working. The strangest thing is that if you leave it for a while, it starts working again on its own. And the oddest part is that it only happens when it's very cold, around 5 or 6 degrees Celsius. Thanks in advance.
16 years 1 month before - 16 years 1 month before #10567 by manual-mecanica
Manual-mechanics response on the topic Re: Power window electrical failure D Max
WHAT YEAR IS YOUR DMAX
Latest edition: 16 years 1 month before by .
16 years 1 month before #10568 by manual-mecanica
It's from 2006. Thank you for your inquiry.
16 years 1 month before #10607 by manual-mecanica
It's not as strange as you think. Check the controller's electrical connector and clean it with contact cleaner. If you want, you can put a little Vaseline on it to prevent it from happening, but it's just a contact problem.
16 years 1 month before #10615 by manual-mecanica
OK thank you very much, I'll try it and confirm the results.
