Yellow motor check on
15 years 11 months before #10525 by manual-mecanica
Yellow cock of the burning motor published by manual-mecanica
Hello everyone.
You see I have a problem with my vehicle, it turns out that today my father took the car and when I arrive he says that since the engine started, the light of Check was turned on at all times, and consulted the I30 manual and although mine is a Getz is the same, and the symptoms are the ones that puts in that manual, it loses power when it rises slopes and the engine sounds more than normal. My father says he is working with a single piston. The funny thing is that my mother this morning has turned on the same light but only about 10 minutes. Is it normal for the engine to start every time, but in these cases it can be and how is it solved?
I await your help carefully, and gatias in advance greetings:( : Dry:
15 years 11 months before #10533 by manual-mecanica
Manual-Mecanica Response on the Re: Yellow Light Check of the Motor Light
Look Sergio for the symptoms that you tell me, most likely it is the subject of ignition coils
so the car sounds more the engine and it seems that it goes in less cylinders, in reality you are walked in less cylinders, I would go there anyway the only way of checking it well would be making a diagnosis with a makina, but almost sure it is that in some cylinder you are missing.
all the best.
15 years 11 months before #10536 by manual-mecanica
To be able to advise you better, it would be very helpful to know what car/engine it is. Try to find out the fault codes with a scanner or coding reader and based on this you can see what to do. If there are failures that make the light of the check and this light goes out alone when the condition that originated it no longer exists, after some handling cycles. Greetings.
15 years 11 months before #10554 by manual-mecanica
Ams and the friends already solve the problem, take the vehicle to the mechanic and do not see less bad than the car for little, they made a cabio of oil, the oil filter, the four spark plugs changed, and the brake pads changed. Ams The Yellow Light of Check kept sighing, in the morning, then in the afternoon it was fixed and when I left the tade-night the light took off the light. Thank you all, and thanks to the mechanic that I catch the vehicle the same morning.
Greetings to all.: HUH:
