Renaut Megane 1.9d problems of 1999
15 years 9 months before #10505 by manual-mecanica
Manual-Mecanica Response on the Renaut Megane 1.9D Problems of 1999
Change the motor temperature sensor, the problem is that it does not measure well and the pump does not injection the proper proportion when it is cold. They could be more things, but from what you tell me, you can try to change it, since it costs about € 10.
15 years 9 months before #10519 by manual-mecanica
Thank you will be the next thing you do, I will keep you informed
15 years 8 months before #10647 by manual-mecanica
Hello today I have disassembled and disconnected the EGR valve and it seems a lie but it is another car, it has been the solution to the problems. I have had some small failure like the abs but is perfect.
Thanks for your help: Laugh:
15 years 8 months before #10651 by manual-mecanica
Hello, the white smoke is air in the oil circuit, it is usually a breakage filtration of some duct in the low pressure circuit (verify filters, ducts, elabadora pump) The second is Scanare and follow protocol according to code.
