Renaut Megane 1.9d problems of 1999
16 years 1 month before #10461 by manual-mecanica
Renaut Megane 1.9D 1999 problems published by Manual-Mecanica
Hello: I would like if someone could lend me a hand with a problem in a megane diesel series 1
The problem is that when the car starts it fails and throws enough white smoke, when it passes 3000 laps the engine goes better, but the main problem is that when I am a km, the temperature light and the stop light is turned on and the car does not exceed 1500rpm and the engine is left without strength, this is almost always. When I turn off the car and locked it again sometimes, then the light of the ABS is turned on and it does not work, I fear it is something of the wiring or the switchboard.
I would appreciate your help.
16 years 1 month before #10463 by manual-mecanica
Manual-Mecanica Response on the Renaut Megane 1.9D Problems of 1999
Hello partner, consume refrigerant liquid? Usually the white smoke indicates the presence of water vapor'revisa if it is not missing fluid in the radiator because it may be due to damage to the Board of the Boper, send us more details so that we can help you, a hug.
16 years 1 month before #10464 by manual-mecanica
Thanks for answering so fast, it does not consume refrigerant fluid greetings
16 years 1 month before #10470 by manual-mecanica
Hello, check the earth cables, you may have some lazy or sulfatado and do not have the necessary mass for heating and for the car
16 years 1 month before #10504 by manual-mecanica
The cables are reviewed and I have not seen anything, all ok (apparently)
I have thought about the EGR valve.
