how to put the Ford Ka 2003 band
15 years 11 months before #10453 by manual-mecanica
how to put the 2003 Ford Ka band published by Manual-Mecanica
B) Size = 4] Hello, I would like to know if you could help me with this problem is that I break the band and I don't know how I go to put it if there is someone who can help me, I will thank you for my car is Ford ka 1.6l engine [/size] B)
15 years 11 months before #10456 by manual-mecanica
Manual-Mecanica Response on the Re: how to put the Ford Ka 2003 band
I send you this drawing that shows you (more or less how the band is going. You do not need to remove the lighthouse as the description says. Greetings, JUDGE
15 years 11 months before #10457 by manual-mecanica
right now if the file comes
15 years 11 months before #10460 by manual-mecanica
Inside the chest where you design gase emissions comes the band label is the same as a Ford Couer, that a Ford Ikon are the same engine
15 years 11 months before #10466 by manual-mecanica
Right now it is the third time I try to add the file. A versi works.
