Start with Seat Cordoba 1.6 of 2000
16 years 5 days before #10312 by manual-mecanica
Start with Seat Cordoba 1.6 of 2000 published by Manual-Mecanica
Hello everyone,
I have a problem with Seat Cordoba 1.6 in 2000 .. From time to time, when you start you give the Llalve and do not start, you wait 5 minutes and start again although sometimes you have to wait for much more. He does it both cold and hot. In the workshop (unofficial) I have cleaned the monopunto injection with a spray .. but continues to fail. They have also put the machine and it doesn't seem to have failures.
Any idea?
Thank you so much.
16 years 4 days before #10328 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Start Seat Cordoba 1.6 of 2000
You can have problems with the starter engine or simply with the key sheet. Tepend of the noises that Aga, tell us if it makes any noise when trying to start it.
16 years 3 days before #10336 by manual-mecanica
Thanks for the interest ..
Well look .. At first, I gave me the impression that I failed when when I was while it took a long time to finish the noise of the gasoline pump and then a "click" of a relay .. but in the workshop that I have taken it they have told me that when they failed them I seemed to make a noise in the monopunto .. no idea ....
thanks,
greetings.
16 years 3 days before #10343 by manual-mecanica
Friend I have never heard a noise in the injection, but if it starts and does not turn on the possibilities they are two, there is no spark or there is no fuel, there is not much more, but the truth that I would have to have it to see it and study it for what you comment there are no symptoms of anything, but you can fix when it makes the failure if there is a spark, and fuel, one of the two is not, or is bad. Check that first to make me an image of the problem.
16 years 3 days before #10344 by manual-mecanica
Another friend, your vehicle has immobilizer?
