By pass to the immobilizer?
15 years 11 months before #10308 by manual-mecanica
By pass to the immobilizer? Posted by manual-mecanica
Hello friends, you can do by pass to any immobilizer
15 years 11 months before #10324 by manual-mecanica
Manual-Mecanica response on the Re: By Pass to the Immobilizer?
Juanra can be to anyone that changes is the way he is managed and that depends directly on the fact that you eat your immobilizer, that is, there are some that command the pump current, others the initial injection pulse directly in the injector, and another command the spark. Others use a key signal to unlock an internal start switch. I know that the injection pulse can be unlocked, jumping the box that is the serca of the injection range, the direct cables are removed and put on, the two ends that are short, but of the others I do not have it very clear, I will try to look for the information to put it in any post.
15 years 11 months before #10325 by manual-mecanica
of Ke treats the immobiller
