Pick up 504 cardan problem
15 years 11 months before #10279 by manual-mecanica
Pick UP 504 cardan problem published by Manual-Mecanica
Hello everyone, I am having problems with the rear stress of the cardan of my truck, weld it and cut every two or three months, the cardan new step the same. The truck is used in a normal way, it is not loaded, it normally walks by route to no more than 100 km, I always handle it, that is, I don't know what will be happening if someone expert can help me, I will appreciate it very much !!
15 years 11 months before #10282 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Cardan de Pick Up 504
Hello friend, that is not a soldier, you have to change the cardan and the Manguito of coupling because it takes play in the stretch marks and you will always have those problems, greetings.
15 years 11 months before #10290 by manual-mecanica
Thank you Jal for your answer, we already tried new cardan. Now they are seeing if the gun is crooked or something. I will also take into account your advice. B) B)
