Problem with 4WD Isuzu D-Max 3.0
15 years 9 months before #10185 by manual-mecanica
Problem with 4WD Isuzu D-Max 3.0 Published by Manual-Mecanica
Hello, the problem with this D-Max is that someone disconnects the 4WD engine connector to see how it was connected to repair another and when the car came out Check 4WD and did not connect the double again never told me that the only thing I must do is reset the double computer but I do not know how the procedure is. Thanks for your help friends.
15 years 9 months before #10199 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with 4WD Isuzu D-Max 3.0
Juanra78, the most useful and rapid way is the formatted by means of a scanner, since the manual operation does not give much results in Isuzu engines, but you can try the negative cable of the battery, for a period of thirty seconds to one minute, but I recommend you the scanner so you go out of the doubt of the fault.
15 years 9 months before #10209 by manual-mecanica
Well, in this case, it is where one strange the double mechanic of the trucks that bring it, the electronic system that the ISUZU brings has this inconvenience that its system does not go independent then, there is on load on elected energy peaks
. Reset the double module as I explain in the graph without touching the two bridges because you can take away the module, you do this with two small wires, you open the swich and bridges until you click the module and problem solving, I advise you to learn that you learn yourself because it usually happens very often and it is very very very Nor are complex tam ,,,,
lucky if you have any questions with pleasure I will help you ....
15 years 9 months before #10210 by manual-mecanica
The graph does not appear. Please send me an MP
15 years 8 months before #10794 by manual-mecanica
Hello, you can send me the graph too, I have the same problem.
thank you
