Axials and trice
16 years 2 days before #10116 by manual-mecanica
Axials and trice published by Manual-Mecanica
Hello, someone could give me data on how to change the axials and trice?
16 years 2 days before #10120 by manual-mecanica
Manual-Mecanica Response on the Re: Axials and Tricetas
Hello partner, you have to disassemble the half -making and remove the rubber bellows, in the homocinetic joints you have insurance in the back you open a clamp and outward strips, the triceta has a seventeenth ring, you open it and take it out, change both bellows, I hope it helps you, a hug.
16 years 1 day before #10132 by manual-mecanica
It is as Jal says, but Hojo if they told you that it was like Fiat's, since there are many Fiat who have a bearing inside the bellows on the box, it is easy to get it out, but so that you do not force the bellows.
16 years 1 day before #10144 by manual-mecanica
Hello, how are you looking, I tell you that to disarm it it is not complicated, it just takes you for a while, first you will have to loosen the wheel center nut, I think it is a 30 mm tube, which holds the semi -the semi -a then The model has 6mm exagonal screws that are removed with a support for the bellows there is the trizlet
15 years 11 months before #10220 by manual-mecanica
Thank you to all boys, any thing .................... I sell tavria with horse traction !!!!!, hahahaha, a hug to all !!!
