306xn 1.4
16 years 1 month before #10109 by manual-mecanica
306XN 1.4 Published by Manual-Mecanica
Hello everyone I have a problem with my car, the engine has no strength and gets a lot of smoke.:( :( What can be? Thank you I expect answers and advice.
16 years 1 month before #10113 by manual-mecanica
Manual-Mecanica Response on the Re: 306xn 1.4
Hello Juli009 we do not have a problem in helping you but give us more data, when you throw the smoke by accelerating it to the relay, what color is the smoke, white blue white, greetings and luck
16 years 1 month before #10138 by manual-mecanica
The color of the smoke is blue, when accelerate throws, but much also in Relay, I do not know, can the engine be bad? With a change of segments you can grind? Or do I have to change the engine? What does it get more profitable? Thank you? Thank you? :( :(
16 years 1 month before #10142 by manual-mecanica
Hi Juli Mira, you don't have to change the engine do not worry about that, the blue smoke is oil that you are burning in the combustion cameras, this can be for two causes, that are in poor condition, the seals or guidelines of valves, or because of the rings, the problem is that in order to determine this, it is necessary Make a complete adjustment, but the first thing is to identify where the oil is passed, it is not so serious, do not worry, luck and greetings. Now if the smoke is little, you can try an oil additive, all this thinking that your oil is in good condition and you are not killed.
16 years 1 month before #10155 by manual-mecanica
Thank you very much, Kikemec, you know some mec? I'm from Madrid
