White smoke problem
15 years 9 months before #10097 by manual-mecanica
White smoke problem published by Manual-Mecanica
hello. I have a problem in a G9T-720 Motor Renault Master.
When the cold arrnaco, I throw a lot of white smoke until it heats up and works perfectly. I have already taken it to several mechanics, and nobody finds the problem.
Let's see if someone has happened to him and helps me.
thank you.
15 years 9 months before #10101 by manual-mecanica
Manual-Mecanica Answer on the Re: White smoke problem
Look at the white smoke in the vehicles it is because the water is passed to combustion, but at cold start that is to say in the morning it is normal, since the condensation of water in the catalyt (Packaging), Cheka and Notanos.
15 years 9 months before #10102 by manual-mecanica
It is water vapor The most caused button or packaging. Decrease the water level of your vehicle?
15 years 9 months before #10301 by manual-mecanica
Hello friends! Greetings.
It seems to me that if your car is driving white smoke, you should verify several things:
Do you consume motor oil? Consume water/refrigerant? Is the engine overheat? How many km does that engine have? It is also advisable to perform a compression test to rule out that it is oil pass through the rings.
If your engine consumes oil, and presents the symptoms that you describe, it is likely to be cold oil consumption by worn cylinder rings, when heated, the rings dilate increasing their size and thus improve compression and decrease the oil passage to the combustion camera. Check the spark plugs, they may be full of oil.
It may also be that the camera (cover or cylinder head) presents deformations in the union plane to the block that can be caused by motor overheating.
However, it seems very rare for mechanics to review your car and have not found the cause of this abnormality.
I hope I have helped
15 years 9 months before #10412 by manual-mecanica
Check if your vehicle loses oil or cooling water if it does change the butt joint k must be that
