Ford Fiesta 93
16 years 3 days before #10091 by manual-mecanica
Ford Fiesta 93 published by Manual-Mecanica
I have a problem with the car that downloads the battery and I don't know how to repair it! It always leaves me lying! What can it be? How can I repair it? Thank you and greetings
16 years 3 days before #10093 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Fiesta 93
You should look if what fails is the alternator and if you may have some contact for some place.
16 years 3 days before #10094 by manual-mecanica
Give me more details, are you downloaded for a while, when you circulate?
16 years 2 days before #10100 by manual-mecanica
CHEKEA First of all the alternator load, if it is correct test to see if the battery lowers when the engine is complete You change, the other way of measuring the battery is with the tester connected to start and see until it goes down if less than 11 think of changing the battery.
16 years 2 days before #10111 by manual-mecanica
It is not downloaded alone, when I am going to make the car does not start, the battery is new has 1 month, but it already did it with others is the third that changed (in guarantee battery) the car starts the first days well but then I download it. A greeting and thanks.
