crossroads
16 years 2 months before #9994 by manual-mecanica
Crossing lights published by Manual-Mecanica
Hello good, because the problem is as follows, I have a Renault Clio 2 Phase 1 and the left light does not work, I change it thinking that it is molten but nothing, look if it comes to him tension and does not arrive, the fuses are all fine. If someone can guide me or say where the relays are, or that it can be I would appreciate it.
Thank you.
16 years 2 months before #9996 by manual-mecanica
Manual-Mecanica Response on the Re: crossing lights
The left light that is only the front or both rear and front, is it crossing or the entire optional group?
16 years 2 months before #9999 by manual-mecanica
Hello friend, I can help you but I require the following data, year, vehicle model, engine
with these data may be able to support your problem with my granite of sand. Eye the diagrams I have in English.
16 years 2 months before #10000 by manual-mecanica
The light that does not work is the driver's side, the lighthouse has double optics, the one that does not work is the road, the rest of the vehicle lights work well. The model is a Renault Clio, 1.4 16V, year 2000, Motor K4J, Rxe model.
Thank you.
16 years 2 months before #10005 by manual-mecanica
Look as easy as you can do is bridge the light that works with what you don't, and so you will be fine, why the problem or how to look for it, you will have to follow the cable and this is half cumbersome so I tell you, try to see if it works.
