Ignition cut !!!!!
16 years 3 months before #8971 by manual-mecanica
Ignition cut !!!!! Posted by manual-mecanica
Dear companions, in a Glxi lancer 1.6 year 1997, makes a power out of turn on when it accelerates in low turns in a high change and even when it also regulates. Behavior: Motor light is turned on in the board as if stopped, (which does not stop the engine) and continue on and turn off the engine. I have controlled fuel pump relat and nothing ... what can you tell me to solve this problem ???
16 years 3 months before #8974 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition cut !!!!!
Check the Candela cables, it is possible that some this land, Lugo Check that you do not have a false contact in the harness of the engine components. (Timer, sensors, fuse box, battery etc ...)
16 years 3 months before #9002 by manual-mecanica
Ok I have as soon as possible. Thank you!!
