I'm looking for Megane Scenic Manual
16 years 7 months before #7346 by manual-mecanica
I'm looking for Megane Scenic manual posted by Manual-Mecanica
Hello everyone. I am looking for an electrical scheme of the Megane Scenic. He has already gone through two Renault dealers and have not found the ruling he has. The problem in question is that this specific car has stopped measuring the speed at which it is circulating. The adjacent problem is that it has stopped counting the kilometers that are traveled.
I would appreciate any comments. Greetings to all.
16 years 7 months before #7351 by manual-mecanica
Manual-Mecanica Answer on the Re: I'm looking for Manual Megane Scenic
The tacometer does work? Does not turn on a breakdown or red light Service.
If the Kilometers account works even if you do not tell them, the Averia or Service light is not turned on,
it would be necessary to verify but almost certainly fail in the Institute box.
I hope to be wrong, not to help you but to make it less expensive to repair it, if it is in guarantee.
Greetings from Tenerifeb)
16 years 7 months before #7356 by manual-mecanica
First of all, thank my request for help. If this is the case it would not be complicated to inject a signal emulating the tachometer signal and, thus, to rule out other causes.
The truth is that it does not mark fault even in the orange fault light or in the red light of critical defect. It seems that then what happens is losing the tachometer signal in some syntium.
Do you know what type of signal is the one that must be introduced to the control table to be able to verify that the signal also comes but it is the picture that does not mark it?
Greetings from Valencia
16 years 7 months before #7378 by manual-mecanica
I have the Megane Scenic manual, but not for sure what your model is, and if it is a European model, although the signal will be for everyone, but please give me the number of the frame and find it out.
When my specialty is the German vehicles always like to learn from the rest.
greetings..;)
16 years 7 months before #7388 by manual-mecanica
HELLO ! Thank you very much for trying for this topic.
This is the 2000 Megane Scenic but I have great memory capacity on my PC you have no problem sending me all the documentation you have and I look at it in a little while and I look for the information I need.
And thank you very much.
