Citroen Jumper Electric Scheme 1.9 D 1999
11 years 9 months before #45318 by manual-mecanica
Electric scheme Citroen Jumper 1.9 D 1999 published by Manual-Mecanica
About 2 months ago, driving the engine stopped. When trying to start it, the immobilizer indicator was not turned off so I do not start, change the fuse No. 16 S (Diesel electric stop) with the preheating symbols and lack of fuel but crossed out.
Changing the fuse the van started normally, but the failure was repeated 3 times more in 2 months.
Last Friday I could not start it by changing the fuse because the fuse breaks putting the contact.
I found under the steering wheel the immobilizer switchboard (reference 46417024 of yellow). I disconnect it, change the fuse, put the contact and jump the fuse. (I deduce that there is no problem in the switchboard.)
If someone can help me because I don't have money to take the van to the mechanic.
Thank you very much,
Patrick
11 years 8 months before #45322 by manual-mecanica
Manual-Mecanica Response on the subject Electric Scheme Citroen Jumper 1.9 D 1999
You should check wiring that goes to the pump (electrovalvula stop), tabien may be due to some derivation in the postitive of the mass heater. Greetings!!
11 years 8 months before #45323 by manual-mecanica
Thank you very much for answering.
I will try to find the wiring failure.
All the best,
