I need Renault K4M 1.6 16V motor manual
13 years 11 months before #28493 by manual-mecanica
I need Renault K4M 1.6 16V Motor Manual published by Manual-Mecanica
The distribution strap is basically cut, and I am lighting specifications, the most urgent that I lack are the values ​​of cover torque and camshafts. If someone can facilitate the excellent manual !!!
THANK YOU!
13 years 11 months before #28497 by manual-mecanica
Manual-Mecanica Response on the Re: I need Motor Manual Renault K4M 1.6 16V
Hello, how are you, if you break the distribution band I recommend that you lower your head and check all the valves because it is certain that they have been crooked, there are times that all are folded and there are times that Nadamas 4, but for you to work twice if it is recommended that you lower your head. Czech this link www.automecanico.com
13 years 11 months before #28500 by manual-mecanica
Yes, I took it out and the escape 8 folded, the admission are not noticeable, but already send the lid to the rectifier.
Thank you,
the strap is not cut ... the cranks of the crankshaft is loosen that in this engine does not have a key ... grrr ...: Angry:
13 years 11 months before #28501 by manual-mecanica
13 years 11 months before #28503 by manual-mecanica
The manual passes you
