WHAT'S UP, EVERYONE...
I'VE FOUND SOME MANUALS FOR THIS ENGINE IN SPANISH (1.0, 1.6 AND 2.0 / KA, FIESTA AND ECOSPORT) APPARENTLY 2005 MODELS... THIS IS THE CONTENTS LIST:
Hydraulic Brake Actuation.pdf
Servo-Brake Actuation.pdf
Air conditioning.pdf
Alternator and Regulator.pdf
Steering Articulations.pdf
Seats and Safety Belts.pdf
Battery Charging System - General Information.pdf
Battery, Mount and Cables.pdf
Horn.pdf
Manual Gearbox External Controls.pdf
Manual Gearbox G5M 4x4.pdf
Manual Gearbox and Clutch General Information.pdf
Manual Gearbox.pdf
Heating and Ventilation.pdf
Cardan 4x4.pdf
Complete Body, Additions and Mounting System.pdf
Front Panel Bodywork.pdf
Address column.pdf
Fuel, Feeding and Control 2.0L Duratec.pdf
ABS Anti-lock Braking System.pdf
Climate Control General Information.pdf
Fuel Emissions Control.pdf
1.4L Duratorq-TDCi (DV) Diesel Engine Emission Control.pdf
Acceleration Control.pdf
1.6L Zetec Rocam Engine Emission Level Control.pdf
Climate control systems.pdf
Clutch controls.pdf
Electronic Controls - Zetec Rocam and Supercharger Engines.pdf
Jack and Lift.pdf
Windows and window lifts.pdf
Fuel Tank and Lines.pdf
Power Direction.pdf
Air Distribution and Filters.pdf
Rear Axle Differential 4x4.pdf
Clutch.pdf
External rearview mirror.pdf
Front Disc Brake.pdf
Handbrake.pdf
Drum brakes.pdf
Group of Instruments Codes.pdf
Engine Ignition 1.6L Zetec Rocam and 2.0L Duratec.pdf
Exterior Lighting.pdf
Steering Column Switches.pdf
Windshield wiper and washer.pdf
Handles, latches, locks and mechanisms.pdf
1.6L Zetec Rocam Engine.pdf
2.0L Duratec Engine.pdf
DuraTorq TDCi 1.4l engine.pdf
Instrument Panel and Lighting.pdf
Instrument Panel and Center Console.pdf
Bumpers.pdf
Pulleys or Belts.pdf
Communication network of the modules.pdf
Cooling of the 1.4 l Duratorq-TDCi (DV) Diesel Engine.pdf
Engine Cooling 1.0L 1.6L and Supercharger.pdf
2.0L Duratec Engine Cooling.pdf
Wheels and Tires.pdf
Front Half Shafts.pdf
Rear axle shafts 4x4.pdf
Fuel system Turbocharged 1.4 l Duratorq TDCi (DV) Diesel.pdf
Passive anti-theft system.pdf
Fuel supply system 1.4 l Duratorq-TDCi (DV) Diesel.pdf
Fuel Feed System 1.6L Zetec Rocam.pdf
Engine Starting System 1.6L Zetec Rocam.pdf
2.0L Engine Starting System.pdf
Audio System - General Information.pdf
Heating system 1.4 l Duratorq-TDCi (DV) Diesel.pdf
Fuel System General Information.pdf
General Information Management System.pdf
Exhaust System.pdf
Brake System General Information.pdf
Passive Safety System (Airbag).pdf
Suspension System General Information.pdf
Engine Systems General Information (Diagnosis and Verification).pdf
Front Suspension.pdf
Rear Suspension.pdf
Interior Upholstery.pdf
The download link is via Rapidshare and the file size is 68 MB... If you have any problems, please let me know.
rapidshare.com/files/125728491/Manual_Taller_EcoSport.zip.html
