I request engineers from Renault Express 1.9 D
16 years 10 months before - 16 years 10 months before #6499 by manual-mecanica
Manual-Mecanica Response on the Reault Express Motor data 1.9
I consult if someone can tell me what function the red relay of the image has (next to the refrigerant tank.
Some erroneous connection causes it to stick when the battery is connected, which is downloaded in some hours of inactivity. I guess someone changed the connection that should feed the relay from the contact key and not directly from the battery.
16 years 10 months before #6500 by manual-mecanica
Some erroneous connection causes it to stick when the battery is connected, with which it is downloaded in some hours of inactivity. I suppose that someone changed the connection that should feed the relay from the contact key and not directly from the battery. [IMG SIZE = 150] [/IMG]
2 years 8 months before #54414 by manual-mecanica
Thank you very much for sharing the manual of those trucks I worked perfect.
