Air conditioning manual
15 years 7 months before #12511 by manual-mecanica
Air conditioning manual published by Manual-Mecanica
Hello everyone:
I have a peugeot 306 gasoline from 1999 and I have a lot of problem with the air conditioning, my question is some of you a manual for the air?
Thank you very much in advance.
15 years 7 months before #12531 by manual-mecanica
Manual-Mecanica Response on the Re: Air conditioning manual
what is your problem or exactly that Nesty : Woohoo:
15 years 7 months before #12550 by manual-mecanica
It is that I am not one what happens to him I have taken several times to the air technician and does not find the problem, he has looked at it with the inflaroos lamp and does not hate, he thinks that it is the joint that carries inside the compressor, but after opening him paid 120 euros to open it, two veins do not fly from him See and he has repaired some compressor things, now I have that it does not work again.
all the best.
15 years 7 months before #12569 by manual-mecanica
If he put the dye to detect the escape with the ultraviolet light lamp, if not at all, nothing is that the escape is not, in those models it is communicated that the seal or retains the follow of the compressor in order to detect it will have to remove the clutch from the compress in another way that he has X -ray view. Another probable and common leak in that model is the evaporator the fastest way to review it would be the light lamp due to the evaporator drainage
type
of packaging or compressor stamps is very simple for any average technic Does something suppose you should give you any guarantee or not ??? Now in this market there are technical mechanics in A/C excellent, good, regular, bad and we weigh you had a bad experience, try another but always ask that guarantee has the work done that is what slice credibility to a workshop .... greetings and lucky: Woohoo:
15 years 7 months before #12573 by manual-mecanica
Well, first of all, thank you very much for the help, I tell you, I have taken it to the air conditioning specialist and has finally found the fault, after doing all the tests, the first thing he has done is to put hydrogen the press If he has been able to find the ruling, which was the
good repair capacitor costs me in total 374 euros that is not much but I have thought about changing the condenser myself after everything is just to put a joint and the oil, but the oil does not know where it goes? I think the condenser is not or yes?
all the best .
