Clio 1.5dci does not turn on an ignition key
7 years 10 months before #52935 by manual-mecanica
Clio 1.5dci does not turn on an ignition key published by Manual-Mecanica
Hello pretty people as they are I hope that well, I present a common problem in the CLIO DCI 1.5, I tell you, when the Ignition key does not turn on, you push it 2 meters and turn on normal later it works to perfection without failures or loss of power, connect scanner and shows me code 1088, refers to the fuel pressure system, but I measure the pressure and it gives me correct to rpm of the speed of start speed, you It has happened to them if they can inform you, I thank you big hug
7 years 10 months before #52937 by manual-mecanica
Manual-Mecanica Response on the topic 1.5dci does not turn on the ignition key
Good, it is possible that it is because of the key, I have seen several models of that type, which due to an error in the key does not recognize the car and do not start. That may be a greeting.
