Ars
8 years 9 months before #52003 by manual-mecanica
Ars published by Manual-Mecanica
Hello, I would like you to help me with a symbol that comes out on the Sprinter 411 year 2011 is a fixed yellow triangle, in turn I cannot accelerate more than 60 k/h because it is thrown to stop, then it squeezed the ARS button and I can accelerate but it is the intermittent yellow triangle does not go out. This van changed 2 rear tires and the new ones installed them.
8 years 9 months before #52011 by manual-mecanica
Manual-Mecanica Answer on the topic Ars
Hello, it is very important that the pneumatic ones be of the same measure ... the 4. If you placed different pneumatic ones ahead and attract .... that is what the problem is producing in the ABS/control system traction/stavility. SL2 and luck
8 years 9 months before #52012 by manual-mecanica
Hello Josvar.
I think the Ars system will be the ASR that has a car button.
It is Mercedes engineering technology, it is a control system in the traration system.
Cauasa for which it is activated, then an endless one as.
What state is the road. Dry, wet, frost ...
like the pressure of car's tires ...
the system itself serves to control the traction in the event that a wheel wheel will lose stability.
The system measures the RPM of the wheels through a sensor on each wheel.
Collect the information is passed to the switchboard and according to the information obtained governs the electrovalvulas of the ABS sending pressure to the wheel or wheels that lose stability.
Correcting its operation.
We expect a answer to the past to activate the ASR.
Anything you tell me and try to get information.
All the best.
8 years 7 months before #52238 by manual-mecanica
The quality of the tires is also important we must not forget that they are the only point of union with the road and responsible for traction, that can be a problem. Many times www.planetgom.com ">cheap tires usually play bad passes with the balance and comfort of the vehicle.
