Change the label
8 years 8 months before #51973 by manual-mecanica
Change rotula published by manual-mecanica
Hello, you will see a Citroen Saxi 1500 diesel, I would like to know if you can change the front suspension lab
8 years 8 months before #51980 by manual-mecanica
Manual-Mecanica response on the topic Change label
Hello Tijerita, it is best to go to a scrapping and make a complete trapezoid (it is worth little), I already tell you in advance that it is not worth taking out the newspaper (a fairly strong blow comes out) but to put it you will end up damaging it and apart you will not give you any security is a very important piece for security (I say it from experience). Apart, if you only have the overall and the newspaper is broken, it has no clearance, clean it, grease it and change the overall. Greetings!!
8 years 8 months before #51999 by manual-mecanica
Thank you Ismael in the end take it out with a hammer and put it with a press. all the best
