ABS brake failure
9 years 4 weeks before #51561 by manual-mecanica
ABS brake failure published by Manual-Mecanica
Good afternoon.
I have Peugeot 307 2006, I have a problem of ABS failure, it led it to 160km for throwing races, suddenly stops and ABS is activated.
Who has solved this problem, the sensors are fine, the wheel that detects the sensor too, they tell me that possibly a distributor module but they have doubt because nothing appears in the Sccaner .. Alhguien has solved it. I am already 6 months old, I use it carefully. But I want to fix it. greetings..
9 years 3 weeks before #51566 by manual-mecanica
Manual-Mecanica Response on the subject ReBS brake failure
A good scanner should throw the fault if they are the speed sensors that it carries on each wheel or if it reaches the module as they can also see many more parameters.
9 years 3 weeks before #51571 by manual-mecanica
Have the lines to the ABS computer check?
