Gasoline pump is heated
9 years 4 months before #51413 by manual-mecanica
Gasoline pump is heated by manual-mecanica
Good,
I wanted to know, when I am in relief with the car for a while, the gas pump is heated and for the car ... the car does not stop.
9 years 4 months before - 9 years 4 months before #51416 by manual-mecanica
Manual-Mecanica response on the gas pump theme is heated
Hello good ... that usually happens in a fuel feed system when the filters are partially clogged or covered. That produces that the pump consumes more common than desired ... It must do a lot of strength ... Do not cool correctly because of the sameness. If that should also notice what fails more when it has little fuel. A bomb should not consume more than 10 amps. I recommend checking filters and current consumed by the pump ... before replacing it.
Latest edition: 9 years 4 months before by .
