Peugeot Expert does not start
9 years 8 months before #50907 by manual-mecanica
Peugeot Expert does not start published by Manual-Mecanica
Good morning,
I have a Peugeot Expert III of the year 2008 with a 1.6 HDI 9hh engine.
We have proven that the wiring from the switchboard to the pressure sensor is not bad (it has continuity). The high pressure pump has also been proven that it is fine.
But what does not fit me is that after disassembling the pump and reassembling it with the open door it started perfectly, and then when closing it it stopped and did not start again.
On the other hand, looking at the tensions that reach the Rail pressure sensor, the mass pin is only activated when the door is open on some occasions, and less and less. As if the switchboard woke up only when the door is open, and not always
thank you very much for your attention.
9 years 8 months before #50909 by manual-mecanica
Manual-Mecanica response on the Peugeot Expert topic does not start
Something similar happened to me with a megane, the problem ended up being an injector that had the nozzle locked, not accumulating pressure prevented the start.
I hope this data serves you-
A hug
