My Honda Civic Hot and does not start?
9 years 9 months before #50522 by manual-mecanica
My Honda Civic Hot and does not start? Posted by manual-mecanica
Hello, it is the first time I connect ... by favo. Info about my sling civic cupe 94 .. when it reaches the temperature in which it should walk .. when it does not start it almost supplies I think ..
9 years 9 months before #50523 by manual-mecanica
Manual-Mecanica Answer on the subject My Honda Civic Hot and does not start?
Try Main Relay, these failures are very common in Honda. It is located under the left side board. It is coffee color and has 6 cables. Welding fractures and contacts must be resolved. I hope it helps you.
9 years 9 months before #50528 by manual-mecanica
Thanks I try and comment on the result
9 years 9 months before #50529 by manual-mecanica
Thanks I try and comment result.
9 years 8 months before #50663 by manual-mecanica
Check ECT sensor can give false reading
