Installation Horn
9 years 11 months before #50292 by manual-mecanica
Mumpinas Installation Published by Manual-Mecanica
Hello. I want to install two snail speakers each brings two terminals without polarity. In the car horn there is only one terminal. I will have to put a relay. I imagine I am one that I found in the 30A and 12V drawer. I have looked at NET and there are several ways to make connections. In my case, where should I connect the terminals 85,86,87 and 30? The fuse serves me the 15th but where do I install it? .
I will very much appreciate your help. All the best
9 years 11 months before #50294 by manual-mecanica
Manual-Mecanica Response on the topic Installation Horn
Hello, with respect to your description, it is most likely that the only cable you see is the positive feed You have (the one that I suppose has 12 V when you touch the horn switch) goes to the 85 reire terminal, the thermal 86 goes to mass (you can use the same mass with which you feed the speakers, depending on where you place the reread, if not any part of the chassis) and from 87 the cable comes out to the other horn terminal (remember that you previously connected the other terminal to chassis or dough).
The function of the reae in this case would be to bridge the Temónal 30 with the 87 every time I food reread by means of the cable that comes from the habitaculus switch (it would be the one that goes to 85 ...)
I hope the data serves you. greetings !
9 years 11 months before #50295 by manual-mecanica
Look at the attachment of the sketch I have made. I understood you well? Thank you so much
9 years 11 months before - 9 years 11 months before #50296 by manual-mecanica
By the way, the horn that comes standard with the car only has a terminal that I imagine is the positive that you comment comes from the steering wheel. This horn is subject by means of a screw to the car, I want to think that you are making a dough.
The two snail speakers that I want to install do come with two terminals each.
All the best
Latest edition: 9 years 11 months before by .
9 years 11 months before - 9 years 11 months before #50297 by manual-mecanica
It doesn't let me upload a photo of the speakers. By the way I imagine that it is important that the section of the installation cable is 1.5 or 2 mm?
