Nissan Sentra B15 Chip key
10 years 1 month before #50018 by manual-mecanica
Nissan Sentra B15 Chip key published by Manual-Mecanica
Hello, who knows if the Nissan Sentra B15, 2005 is a chip key, that is to say that the Swichera is blocked when they check the computer?
10 years 1 month before #50019 by manual-mecanica
Manual-Mecanica Answer on the Nissan Sentra B15 Chip Key
Hello Alexis as you are
if the B15 model uses a key with code that in Nissan is called the NATS system
when changing the ECM, PCM, Immu and the same key must be encoded asking for the codes A Factory can be extracted the old code with Consult team but still there to ask for the code to factory since with the code that gives you the consult it is to enter the manufacturing portal and there are the new codes. The old
