cylinder lid sensor
10 years 2 months before #49791 by manual-mecanica
cylinder lid sensor posted by manual-mecanica
hello!! I'm new x here, I have a Toyota Hilux SRV 3.0 1KD Model 2008, I bought it with 2000 km. It turns out that it has a cut cable, I do not know if it is a sensor, it is located in the cylinder cover in the right front, behind the compressor, it comes out in black lining with an orange ring and then it is still Mayo but I am looking for where it can go and I find nothing !!
Another thing, I noticed a couple such as the water
was missing and the same week was the same, I began to check it and I saw that the water tacho was filled with compression, changing radiator, thermostat and pump and it remains the same, it does not lift me temperature but they told me that it is a small fissure in the joint
