RENAULT ESPACE LL 1994 Air conditioning
10 years 4 months before #49655 by manual-mecanica
Renault Espace II 1994 Air Conditioning Published by manual-mecanica
Although it's quite old, I rebuilt the engine 7 years ago and it's been regularly serviced.
The only problem I have is with the air conditioning. It cools well until the engine reaches operating temperature, then it starts blowing hot air.
If I turn off the AC but leave both cooling systems running (I have a separate control) and lower the coolant temperature, then turn the AC back on, it cools normally until the coolant heats up again. I know they're two separate circuits, but I don't understand why.
Any suggestions?
Thanks.
10 years 4 months before #49669 by manual-mecanica
Manual-mechanical response on the topic of Renault Espace II 1994 Air Conditioning
I'm asking
when the AC is on, do the fans turn on automatically?
Or do you activate them yourself?
10 years 4 months before #49672 by manual-mecanica
Thanks, Antonio.
I've discovered that the problem is with the second speed on one of the fans.
I've swapped the two relays it has, and they seem to be fine. I need to find two more, as I think one is faulty.
10 years 4 months before #49673 by manual-mecanica
10 years 4 months before #49688 by manual-mecanica
Okay, fixed.
Of the several relays it has, I swapped a couple this morning and found one that wasn't working.
€4 and it's fixed
. The problem was that when only one fan was running, the temperature rose
excessively and the AC cut out.
Thanks anyway for your interest.
Regards
