P0171 error
10 years 3 months before #49565 by manual-mecanica
P0171 error posted by manual-mecanica
Hi ... how are you .. someone Pordria giving me a hand with a Ford Fiesta 1998 .. which broke a mistake for scanner P0171 .. I already clean the MAF sensor that was a solution but still with problems in the walk tends to stop ...
This error appears as a poor mix in bank 1 ... does anyone spend something similar?
thank you so much
10 years 3 months before #49573 by manual-mecanica
Manual-Mecanica Answer on the subject Error P0171
Hello, I agree with the P0171 code these are some causes that probate it: - Admission air leaks
Front defective sensor with oxygen heating
- The
defective fuel injectors - Exhaust gas leaks It's too poor, I hope it serves you luck.
10 years 3 months before #49604 by manual-mecanica
Check all your empty hoses well, even those that go to the powders are not available to these hoses, you have to disassemble a bit to check them well. Thus I have solved that code in Ford.
