Ignition coil problem fiat uno
10 years 3 months before #49546 by manual-mecanica
Ignition Fiat Uno problem published by Manual-Mecanica
Good friends The problem of my car is that it places the hot ignition coils to the end that is damaged I have placed a 2.3 ohm resistor cable but then it fails, my coil is no longer heated is 2.6 ohm but searching in Google I got that the original boibna of electronic ignition with bosch 9220087005 ignition module that this uses coil with the previous ohmiaje said the other is that platinum coils serve in electronics on since those are usually 2.6 to 3 omh
PD. Buy a Bosch coil by Amazom of 3ohm but I think it won't serve me
10 years 3 months before #49599 by manual-mecanica
Manual-Mecanica response on the problem with Ignition Fiat Uno
Hello, the problem may not be the coils, but the electronic voltage regulator contained in the alternator, check the load made by the alternator at approximately 2000 rpm if it exceeds 14V is overloading the circuit. Greetings
10 years 3 months before #49601 by manual-mecanica
Good friend already check the alternator send 13.2 volt in high speed 3000rpm
