Help with an ax
10 years 5 months before #49267 by manual-mecanica
Help with an AX published by Manual-Mecanica
Hello I have a Citroen Ax 1.1 monopunto that has a very poor performance of I would like to know that it can be influencing comments thank you very much
10 years 5 months before #49271 by manual-mecanica
Manual-Mecanica response on the subject helps with an ax
If the spark plugs are fine (and they are theirs), filters and oil, check the correct draft of the distribution belt, taque adjustment, now you have to look at the gasoline filter, check the injection body (the injector, see if it pulverizes well)
