Tsuru Red Tapa Problem 8 Valves
10 years 7 months before #48813 by manual-mecanica
Tsuru Red Tapa Problem 8 Valves posted by Manual-Mecanica
Good night gentlemen My question is that the workshop manual helps me to repair my tsuru 8 valves Red cover year 94 and second before this is that the capitas left me badly in the lathe began to pass oil and throw smoke that above x revolutions rpm no longer vent anything now A fan of mechanics I have no way to check the compression or something else I want to throw myself like this to repair it from being necessary thanks friends
10 years 7 months before #48838 by manual-mecanica
Manual-Mecanica Response on the problem subject in Tsuru Red Cover 8 Valves
Hi Escot02, (I don't know what are the "capuchones" ...) but for what you say: if only burns oil to a few revolutions; Possible wear in vessel or clearance in the guides of these, but if it is burning all the time, or you are broken some grease segment, or some scratch in a cylinder, or if they have mechanized the cylinders, they may not do it well and do not adjust the cylinder piston well. To disassemble the spark plugs to see how many are greased, if there is none, the thing can be in guides or seals of an escape valve. In any CCASA, lead him to look at him. Greetings!
