Xsara Picasso 1.800i 16V Control Panel
10 years 11 months before #48344 by manual-mecanica
Xsara Picasso 1.800i 16V Control Panel Published by Manual-Mecanica
Hello community, I have an Xsara Picasso 1.800i of 16 valves, it was my father -in And the last one that had some burned control panel bulbs, well I focus on the burned control panel bulbs.
, according to a manual that I got, it is easy to change. Make the change, take out the panel and disconnect from the two anti -dumb connectors that it has, hahaha, I call them so because there is no way to be confused when installing them again, and well once the bulbs were changed, the problem began, the bulbs of course T5 of 12V of 1.2W, at the time of lighting the car, the indicators of the right were lit perfectly, but those on the left. Battery or alternator witness, the speed score, etc., which is where the burned bulbs were It was a simple change of bulbs, and now the biggest enigma, when I turn on the car before taking out the panel that had already burned, the altian light witness no longer turned on and everything worked at the
first
