Witnesses of witnesses my goal 1.9 sd diesel was left
10 years 10 months before #48264 by manual-mecanica
published by Manual-Mecanica was left
As they are friends, I tell you my problem to have if someone can give me any solution, I tell you that I have a 2000 Dublin model with 1.9 SD diesel engine, a few days ago I came traveling on the highway and little to reach my destination from one moment from one moment to another the engine stopped, the tacometer, the velocimeter, the velocimetter and did not turn on any light of any witness, cut contact and come back to it, Witness, neither preheating, nor water, nor oil pressure, the two watches both the hateful and the clock of the hour is perfectly.
To all this the joint is also breathed, which surprises me since I did not fail or struggled or hit more than normal and the speed at which I went to the time of this was between 100 km/Hy 110km/h
I am looking for the electrical diagram, someone could give me a hand please ..
10 years 10 months before #48265 by manual-mecanica
Manual-Mecanica Answer on the subject , witnesses of witnesses my goal 1.9 SD Diesel is left
Wow, kotteir !! He who stops like this without more, and does not give again I think you say that it does not start ... Battery does not seem to be, you do not comment if the starter engine turns when giving the key, very similar to this happened .. I would remove the cylinder head and see the taes if there is no broken or see the draft of the distribution belt, these golf when they already have km. Piñon of the cranks are famous. I hope you are lucky and not be the one that I tell you, it is checked quickly. Luck!!
