Subaru Leone Turbo does not accelerate when loading the turbo
10 years 11 months before - 10 years 11 months before #47955 by manual-mecanica
Friends, I need to receive opinions, instructions or some help with my sub -Uru Leone Turbo Coupe of 90 '
It happens that the car is the relatively cold engine, accelerates super well, loading 0.5 bar (stock) but when the engine is heating a little more, it no longer accelerates when loading the turbo 0.2 bar up and begins to give "pull" the engine ...
I have checked the point of the point of the distribution belt And everything ok ...
If someone has happened to something similar I would like to receive a little help and tell me what I can do. From beforehand thanks
PD: the car has changed the turbo for a Garrett A/R .48, Intercooler Sti, Blow Off Hks and exhaust pipe in 3 "
10 years 11 months before #47967 by manual-mecanica
Manual-Mecanica response on the subject Subaru Leone Turbo does not accelerate when loading the turbo
It would be good for you to tell us if this began to happen as soon as those changes (turbo, etc.) or if the whole worked well and has begun to do it now. I think that if it has been when making those modifications, it is that: when cold the mixture is richer and it is relatively well but when it heats, the hot mixture is poor and if you have increased the flow rate of admission, (that the turbo target more air, for example) by accelerating the injectors do not give enough supply to be "shorts" and from there that drown to accelerate, to see more opinions. Greetings!!
