Chevrolet S10
10 years 11 months before #47890 by manual-mecanica
Chevrolet S10 published by Manual-Mecanica
Hello, I hope and someone can help me I have a Chevrolet S10 mode. 1985 TBI 4 cylinders 2.5 motor and my problem is that when I have been starting a half hour that starts starting in each top of the semaphore Etz. It goes out to me already takes it to the Carburetors Hospital and the mechanic also the Czech and nothing found anything. They have already changed Cabes, full tuning gasoline pump, Map, well with the adjustment has but still the same I hope you can help me thanks.
10 years 11 months before #47891 by manual-mecanica
Manual-Mecanica Response on the Chevrolet S10
Check valve regulation ... When the engine is heated, valves dilate and do not close completely, but that is checking the resistance of the ignition coil, when it is heated it also increases its resistance, the wire is saturated and does not allow a good current conduction, greetings, greetings
